For no reason , from time to time, my Xperia Z3 starts ringing and keeps doing that until I restart the phone .
Though there is no incoming phone call, no alarm set, nothing. It`s just ringing. I can use the touch screen and hard buttons, but I can`t stop that Sony ring tone to sing .
I bought the phone exactly 1 month ago, simfree, from Amazon .
Any help ? Anyone having the same problem ?
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
I suggest that you go to Settings > Personalization > Manage notifications > the tab "All" > In the top of this list, you may find "Disabled". If you have things that are disabled here, enable them and restart the phone to see if the same behaviour appear.
I`ve just double checked what you suggested . No, all those things under the "All" tab are already ticked . I presume this means they are active .
Any other ideas for me ? Thanks.
How often does the phone ring? Perhaps you could boot the phone into safe mode to see if same thing occurs:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
Happened 3 times within 1 month .
Unfortunately I`ll not be able to keep my phone in safe mode for days or weeks to see if this problem comes back or not. I still have apps to use on a regular basis .
But probably a technical team from Sony has some "tools" to look into any bug problem, isn`t it ? I think this would be a professional approach to this issue . Submitting a log file to a technical team to be analysed ...
