Hi
Might you be inadvertently covering the proximity sensor? That is the thing that prevents you from accidentally accessing functions with your ear or face in the middle of a call. The sensor is just above the visible part of the screen, somewhere near the 'n' in 'Sony Ericsson'. If your hand were to cover this, it would stop the phone from doing much else until the sensor is uncovered.
i think tht was nt the case becz i have tested this error by makin a call to my other number and testing why the screen is not allowing me to use the dialer in between the call and as soon the call ends all the buttons starts working?
i think ur right thnks its working....
Oh good. You probably just need to get used to holding it differently. There is so much that is not in the manual...
