Bluetooth
Not applicable
Bluetooth
I have a mini pro and i cant send or recieve things via bluetooth.
2 REPLIES 2
Not applicable
x10 mini pro does not support file transfer via bluetooth..u need to download an application called 'bluetooth file transfer' from android market..u should give it a try..
Er_Kannan
Contributor
Follow the link to know how to use the software http://techcognizant.blogspot.com/2010/10/blue-tooth-file-transfer-application.html
Certian changes are made in the recent update but the usage is similar as described in the above link.
