Is it possible to install Arnoid Opreating System on X2, If its possible Pls let me know...
Is X2 a multy OS Phone....
Sorce: http://forum.xda-developers.com/showthread.php?t=568397
Hi annipantherx2,
Xperia X2 runs on Windows Mobile and does not support Android as OS.
There are no authorized methods available that allows you to switch OS in any of our phone models.
But can SE design an update using which Windows OS can be replaced by Android..???
SE will never supply Android for the X2!!
Hi Aras,..
Then what SE will do for X2?
If X10 pro can work on android then why X2 can't..???
All users are really not satisfied with the X2..
Please bring back all X2's from market....
before it is too late for SE to maintain its Brand Image in the market...
Hi s.n.rathod,
Xperia X2 will not get the possibilty to change OS.
The phone is delivered with Windows Mobile and this cannot be changed.
Hi, Markus, and aras....
According to you, after reading all complaints of X2, don't you think that SE X2 requires still one more upgrade???
Then why SE is not thinking about X2 users..??
Don't you agree with all the complaints??
Is there any solution???
Yes, I do think the X2 could work better. It is buggy and sluggish but not because of WM 6.5. The problem is some of the SE software.
Though many users complain on this board the majority of X2 users probably find the X2 ok for their use or just resign. Also it is sometimes difficult to know whether problems are device or user related. I is sad in a way because the X2 is good looking and well build.
You can increase the performance by performing some tweaks and deleting all the SE panels.
I use my X2 a little as I paied quite a lot of money for it but for work I bought an iphone4. Never thought I would get an Apple product but this iphone got it all and it works! Solid rock.
MR2 z ful of bugs man! waiting for MR3!:smileyangry:
I am quite sure there will be no more updates from SE for the X2. Forget about it! Try to get the best out of the phone or sell it. The existing Android phones are not better - they might be in the future versions 4.xx. If you dont like Apple go for the WP7. At least it will not be possible for the phone manufacturers to mess up a WP7 phone with their own homemade software.
