android market problem! !!
Not applicable
Hi all I've got an xperia x10 . Recently I've done a software update and since then can't download stuff from android market. When I'm trying to download anything is just stuck on "starting downloading " . Please help anyone! !!
4 REPLIES 4
KrazyD
Contributor
Try this
Checkin Service -> clear data
Download Manager -> clear data
Google Apps -> clear data
Google Talk Service -> clear data
Login Market and download again
Not applicable
Hi I've try that and didn't work. Is it supposed to let me login again because it didn't
Not applicable
I've got the same problem here. My phone is the Xperia mini. After spending hours on the web trying to fix it, I still haven't found an answer. Please help.
Not applicable
Hi, I met with similar problem and i manage to find the solution from one of the post. Its work for me, hopefully it works for u either. here goes the step (I copied the post anyway)
"ya man! its simple wat i did. since Market wasn't working since its recent update i've opened the app in the settings and uninstalled the updates. here it goes step by step.
Settings>Applications>Manage Applications>Market>Uninstall Updates
Later i've switched off the mobile and switched on and it was working.
I dnt know whether this is correct or not, but its working"
