Hi @Hkm92,
Do you use an SD card with your device? If yes, could you try removing the SD card before trying the software repair and see if this still happens?
repair it with XC and report back
Alternatives on How to backup Xperias
Hi @Hkm92,
Keep us updated.
@Hkm92 Sorry to hear about your SD card. Feel free to let us know if you find anything else in regards to this.
