My phone otherwise working fine has some problems.
Is something wrong with my device or is it a software issue?
Thanks
Hi @Utk1, welcome to our community!
I'm sorry to hear about your phone.
Do you only experience the delay with the input when you are typing on the keyboard or does it occur when you are using the phone as well, for example opening applications from your home screen?
I tried to replicate the behaviour when closing down apps in the task menu of the phone, there was about 20 apps open and I had no troubles swiping away a few of them without ending up at the home screen.
When the phone froze and restarted after a few minutes, do you remember what you were doing in the phone? If you for example used a specific app or service in the phone?
I would recommend rebooting your phone in safe mode which @uliwooly recommended, to make sure that a third party application isn't the cause of the behaviour.
Keep us updated!
@uliwooli
I did as you suggested and it worked. Thanks
Now what should I do? reset my phone or should I wait for android 7 update to be released in India.
Thanks for the update!
As @uliwooly mentioned, if it works fine in safe mode, a third party application is the cause of this.
Firstly, make sure that all your apps are updated. If they already are, you will have to uninstall one app at the time to find out which one that is causing these troubles.
I would recommend that you start with the apps that you have installed most recently.
Keep us updated!
