@Kara28M: the thing is the wallmount charger draws more voltage/power from the outlet this might cause some unwanted effects like screen sensitivity issues. when you charge via usb, the power is lesser so there isn't any "interference"
do you charge thru wallmount adapter? does it happen when you charge it thru usb?
