Hello @Asif12 and welcome to the community!
Do you have any screen protectors or protective cases with magnetic closure installed? If yes, try to remove any of them and see if it helps.
try to perform xperia diagnostics, setting>about phone
since you already performed a software repair using Xperia companion, I suggest you send your device to your local service center Local support
