@BalakumarLakshmanan you are right, in Nougat it's not possible to download or update apps while with mobile data and in roaming. This is not a bug or a feature promoted/endorsed by Sony, it's something that got added to the Android OS by Google. You may want to leave your to Google.
I'm sorry to hear this would it be possible for you to capture this in a bug report and send it to me? I can then forward it internally for investigation.
To do this:
1. Go to Settings > About phone > Build number, tap 7 times on the build number.
2. Go back and select Developer options then turn on "USB debugging".
3. Select Logger buffer size and change it to "4 MB"
4. Restart your phone, then replicate this.
5. Go back to Settings > Developer options, select "Take bug report" followed by "Interactive bug report".
When the report is ready you will receive a notification. Tap the notification to share it. I suggest you upload it to Google Drive and then choose to share a public link to the upload and include the link in the PM.
I had the same problem.But now it,s rectified by googleplays latest update.not only for sony phones but for all phones updated with Nougat.If you have problem with proximity sensor blinking while data transfer is on.Just see our post and reply there in XPERIA-X forum.Thank you
Rectified by further automatic playstore updates thanks Google
@Christofer wrote:I'm sorry to hear this would it be possible for you to capture this in a bug report and send it to me? I can then forward it internally for investigation.
To do this:
https://drive.google.com/file/d/0B61vHQWXYUareHNXeXJBaDFEb00/view?usp=drivesdk
Link to my bug report for proximity sensor blinking issue. It blinks while data transfer is on. We have a separate thread for this one but no one seems to care. I request you to see this and reply me. So many users are having this issue.
