I've got some troubles using my Xperia X with both Wifi and Bluetooth activated at the same time. My home Wifi (2.4GHz) works fine usually, but as soon as I connect my smartphone to any Bluetooth device (I own both an SRS-XB2 loudspeaker and the MDR-1000X) the Wifi loses connection within few seconds. The connection can be re-established in Wifi settings but will fail again within seconds. This error occurred both on Android Marshmallow and Nougat.
This might be the case, but I had never any problems connecting my Z3C to bluetooth devices on the same network.
