I checked in the bathroom with the lights out and only the display of an X Compact illuminated, I made sure the background was bright with black text (Settings) with the highest available brightness and I was not able to find the image blurry. Just to make sure, I also asked a colleague for a second opinion on a different X Compact and we were both unable to see that it was blurry.
It may be that I don't quite understand what you mean, but as I mentioned in my previous post it would be best to have it examined if you are uncertain if your display works correctly.
I found a different post regarding the display where a user had a similar question to yours, could you have a look here and let me know if one of these photos represents what you experience?
You are referring to these lines, right? During specific angles and lighting conditions I was able to see it on our X Compacts here as well, so I would say that it is normal for your device and there is likely nothing wrong with your display. However, I thank you for your feedback regarding this, I'll forward it internally on your behalf!
Any time! Sorry I was a bit slow to understand what you meant, I was so confused there for a while haha.
