That should be the digitizer.
@SOUNI1 Can you post a picture? Does it show up on screenshots?
Also, did you chance settings for white balance?
I understand that it may be hard to show in photos, but when I had a look at our X Compact here at the office I can't experience that the display gets blurry as shown in the photos. Is that an accurate representation of what you experience, or did the camera blur the images?
In any case I'm afraid that I can only advice you to have your device sent to an authorized service center for examination should you suspect that something may be wrong with your display. In order to do so, I recommend that you contact your Local support so that they can assist you. I would gladly assist you if I could, but I'm afraid that even though I work Globally, I am based in the Nordics and have limited service routine knowledge for other markets.
