x compact baterry compatible
Adriano_cwb
Visitor
Is the x compact battery the same as the z5 compact? visually look the same ... I can't find to sell the LIS1634ERPC
1 REPLY 1
profile.country.GB.title
Uliwooly
Expert
@Adriano_cwb
Ebay might be the way to go
https://www.ebay.com/p/11013034109
I'm not sure if you've seen this, but you might need a new NFC antenna
https://www.ifixit.com/Guide/Sony+Xperia+X+Compact+Repairability+Assessment/79127
As for your question, I don't think they are the same size
