How do I activate call waiting on my xperia compact?
Hi @LinaLundsson, welcome to our forum!
You can activate call waiting in an Xperia X Compact if you open up the application called "Phone" > tap the three dots in the top right corner > Settings > Calls > Additional settings > Call waiting.
If it doesn't work or you get an error message, get in touch with your operator so they can check if the function is enabled in your subscription.
Let me know if that helps!
