What's the maximum sized memory card I can use in my Sony Xperia X F5152?
Bought a 256gb but it won't work.
I'ts been suggested 200gb and also 60gb,?
Hi @lowlandcelt,
According to our specifications, you may use an SD card of up to 200GB for your Xperia X.
I have read from some users that they have been able to use an SD card with more available storage than what's specified, but we can only guarantee that it's fully compatible if you use one which is according to our specifications.
You may find this information on our product specification page for Xperia X on our website:
https://www.sonymobile.com/global-en/products/phones/xperia-x/specifications/
Feel free to kudo my post and mark it as the accepted solution if you found it useful, so that other users with the same concern can find the reply as well!
Hi @lowlandcelt,
No worries, you're welcome! Feel free to let me know should there be anything else which I may assist you with.
