When I want to record a video, there is an error "camera is open in another application"
What can I do to solve this. I already made a restart of the phone.
Hi Christofer,
The video works in safe mode. Is there a way to see which application causes the error?
@TwanKurf I'm afraid that it's hard to determine which app that causes this. However, if you found that this behaviour started after installing a new app or after some apps were updated I'd recommend that you try uninstalling these as the first step. I also recommend that you check out @najodleglejszy's suggestion.
Thanks! It's working again.
@TwanKurf I'm glad to hear this!
@najodleglejszy Excellent suggestion, thank you! :smileysmileythumbsup:
