The green text button on the remote control (RMT-TX440E) not working. The LED flashes white but the text menus do not appear on the screen. The remote has the latest software version available. TV model is XR42A90K.
I have the same TV.
If you mean the text service provided by the BBC this is no longer available in newer TVs .
If you have recently bought this TV it may be you are expecting to get the same text service that your older TV had.
In 2019 the BBC said it was going to stop its red button text service.
So TV manufacturers took this and decided not to install the necessary decoder to provide the text service.
in new model TVs.
But along came the pandemic and public opinion and the BBC decided to keep the text service for the foreseeable future.
Sadly it is not something that can be fixed by a software update.
I have three Sony TVs both older than the XR-42A90K and both receive the BBCs text service but not the newer much more expensive XR42.
Disappointing I know, don't know if newer models of Sony (2023 onwards) have restored this function
or if other TV manufacturers have.
I have the same TV.
in new model TVs.
Thanks very much for the explanation. It would have helped if there was a sony helpline or e-mail where these problems can be discussed instead of someone like yourself coming up with the answer. Also why supply a remote with a text button that is non functional.
Sony do not make individual remote controls specifically for one model of TV but rather make remote controls that can be used across a range of models. It may be that the remote(s) that come supplied with the XR-42A90K were made and supplied with older models of Sony TVs that can utilise the Text button.
From Sonys point of view and a financial one it makes sense just to keep it there. It could also be the TV was under development before Sony heard the BBC was planning on dropping the text service, again it makes sense financially not to include the decoder for a service that was not going to exist but not redesign and manufacture a new remote control.
Perhaps the European and the US spec versions of this TV do have the decoder included as other countries may have text services bundled with certain TV channels.
Contacting Sony for a definitive answer well good luck with that.
You could try Customer Services, but you may only get as far as a chat bot. And if you do eventually manage to get to talk with a human the standard response will be ‘have you tried a factory reset’ regardless of what you asked, I wouldn’t give them the credit to be able to tell you what time it is.
