Hi, I wish to download the new update 7.1.1 however it does not allow me to update on a roaming network which is all have(no access to WiFi networks). Alternative I at toted to download it in companion on my pc however it says that the update is not supports and I am required to download it on my handset regardless of the fact that my companion is up to date. Is there a setting I can change to allow desired action? I look forward to your response, thank you.
@Reyhaan sadly Google decided that to avoid inconveniences to Android's users it was wiser to disable any kind of update/upgrades while connected to mobile data and Roaming. It's not something you can change, it's deep into the Android Core.
Only recommendation is to find a WiFi HotSpot and perform the update as you won't be able to install, update or perfom any software update/upgrade while Roaming.
