how can i use fingerprint opening on apps ? the phone is xperia x compact
@rennu if I understood correctly your question you want to use the fingerprint reader to open specific app or to use the fingerprint sensor as login method? This is not something standard, only specific app (mostly banks) will use it as authentication method, mostly all regular app will stick to username/password.
