Hello
On my new X Compact with stock german FW, the navigation bar sometimes hides and i can only see the bar when swiping over the screen...only a reboot brings it back. Is this a bug? i can´t find any setting for that option...
Thank you
@Allesio_84 Thank you for this information and the solution you provided!
