Hi all,
I work in an area with poor 4G/3G coverage and I am often unreacheable if I leave 4G/3G/2G auto toggle because the phone continuously switches from one to the other.
Before Nougat I used to disable 4G from the nortification toggle, and it worked in the following way:
When 4G is on: went full auto 4g/3g/2g
When 4G is off: went to the last selected. In my case 2G
With Nougat update when off it always switches to 3G only mode, forgetting the previous setting; so I am obliged to open the settings and select the 2G mode manually (boring).
Does anybody have a suggestion ?
Thank you.
