Ever since I installed the nougat 7.0 update my sound is soft. Before that it was good, but now it's soft. My volume is at 100% but still soft. It's really frustrating because most of the times I can't hear my ringtone. Any options on what to do?
Hi, I have an Xperia X but after updating to Android 7.0 I noticed the Overall volume level of max speaker output is low whether it's music or making calls using loud speaker on and off. The volume level Indoors is just ok but becomes an issue once outside or in a car. There just isn't enough coming out of the speakers with the given values Sony has programmed.
Is this an ongoing problem with Updated Xperias to Android 7.0 or is there something else that's happening? Is there any updates to increase overall performance in these areas?
Thanks!
