During sw repair for Xperia-X does it require internet continuous
Yes, the Xperia Companion Software will first download the software then install it, download size is around 2.8 GB. If you are re-installing software because of Wifi connectivity issues in 7.1.1 update, I already tried, didn't help.
Hi @rdash084, welcome to the community.
Here are the system requirements for Xperia Companion.
System requirements:
Note! There will be no support for Windows XP or Vista
You will require a continuous internet connection to perform the software repair.
Hp cepat panas dan laging
Fast heat and leggings
gt
My camera is not working
@rdash084 wrote:During sw repair for Xperia-X does it require internet continuous
