Hi @NetBoySteve1 and @YoGem,
I'm afraid that it's a bit difficult for me to recommend a retailer which may carry our chargers as I am not familiar with the Canadian market. My first recommendation would be to check our own E-store over at SonyMobile.com, but unfortunately we do not currently have one for Canada.
A good start would be the Canadian Local support team, they are well informed regarding the local market - and aside from that I would suggest local- and online retailers. If they don't carry it currently, perhaps they can get stock for you?
I wish you all the best, let us know how it went!
No worries @NetBoySteve1, feel free to hit me up should there be anything else which I may assist you with!
is uch12w charger ok with x performance? is it better than uch12 for this model? please help me, I want to buy one but I don't know which one is better. it is important for me to charge faster.
Hi @MohsenR,
Both UCH12 and UCH12W charge with the same speed, the difference is that UCH12W is meant for USB Type C models - but your Xperia X Performance uses microUSB, so if you wish to buy one then I recommend UCH12 for your device.
@Emir Thank you very much
No worries, you're welcome @MohsenR! Feel free to get in touch with me should there be anything else which you may be wondering about.
