I have had these kind of messages/notification 1-2 weeks now.
Have anybody else these same? Is it some Sony software or something I have downloaded?
I can't find any details in the software about it.
Here is screenshot:
https://imgur.com/a/UjSLm
Most probably that's some app you downloaded, belongs to the cleaners/boosters/managers apps family. And to make sure: reboot into safe mode and it should vanish temporarily (safe mode disables all 3rd party apps).
After some testing i found out that the app causing these notifications was ES File Explorer.
It was some new features that must have come from latest update.
Thx. I will check them out.
