Portrait-Mode Symbol
varsn
Visitor
Hey,
I recently got the X Compact and since I don't like auto-rotation, I turned it off. But now I have a new symbol on the right side of the status bar and can't get rid of it. It looks like a portrait-oriented phone. I tried disabling it via Settings -> Display -> system icons but it wasn't even listed there. On my boyfriends X Compact there is no such symbol and we are on the same software version. Tried googling it and couldn't get any information about the symbol at all. Do you guys have any clue, how I can deactivate it?
5 REPLIES 5
Hardy66
Visitor
I toggled auto rotation off and on but I did not observe any icon in the status bar coming up on my X Compact.
But there is a symbol very similar to your description coming up on the left (!) side of the status bar from time to time. This is a reminder that the app "What's New" wants to make some updates - could even be a firmware update as well. As far as I know the only way to get rid of this symbol is to do the updates. Simply pull down the status bar and go for the update.
If my guess is wrong, could you upload a picture of that symbol?
varsn
Visitor
https://www.dropbox.com/s/62v6z3ggcv5ifz8/IMG-20170205-WA0008.jpg?dl=0
Here's a picture of it, it's the most left one. Unfortunately it is clearly related to auto-rotation toggling, since it disappers when I turn it on.
Hardy66
Visitor
Ok, I see that my first guess was absolutely wrong.
The good news: After some investigations I could indeed reproduce this icon on my X Compact - and with it found a way to get rid of it!
Go to settings, scroll down and look if you have an item called "System UI Tuner". Select it, go to first item "Statusbar" and deselect the first "Screen Auto Rotation" - than that symbol is gone!
If you should not find "System UI Tuner" in Settings you first have to activate it:
Pull down the statusbar twice, press and hold the gear in the upper right corner for 5 seconds - then exit and go to settings: now the "System UI Tuner" is there.
bchaitanya04
Visitor
But i didnt get any option in my Xperia X F5122 like UI tunor and the icon is automatically disappearing when i turn auto rotation on but it's still there in portrait mode..Any other way to get rid of it..
Thanks in advance.
Tags (1)
Didrik
Enthusiast
Hey @varsn,
Glad to hear you were able to relevant setting. :smileysmileythumbsup:
There may be some difference in what icons are displayed, depending on what customization the phone has and where the phone was sold. The setting you are referring to however can always be turned off in the system UI menu.
Let me know if you have any other questions!
