There is no volte toggle avaliable after, 7.1.1 update i even tried the *#*#4636*#*# method but no use. Any one plz help me
Online reviews and specs on this phone state that this phone is VoLTE provisioned, but I am not able to use that feature. Reading through the forum on related topic, the solution I get is to make sure that a VoLTE active sim card, be inserted.. Well, as per the screenshot, that's a VoLTE sim card inserted and still I can't find the option to enable VoLTE. I thought Oreo Update will bring this feature but it didn't. Any other method to activate this feature on my phone that doesn't need an "operator firmware" that I honestly do not understand???
Device: Xperia X (F5122) Running on Android 8.0.0 Build Number: 34.4.A.0.364
From the Xperia X manual:
Pay attention to the 1. remark
And don't forget to read the very last sentence.
Android™ 8.0 To enable VoLTE
Android™ 5.0, 5.1, 6.0, 7.0, 7.1 or 7.1.1 To enable VoLTE
Does my Xperia x supports volte
Your Xperia does, that's for sure.
Question is if your provider supports it.
Use Google to find out about the details
I to have same problem
On my phone you can’t enable the rest of the functions....
What can I do to turn Volte on ?
I am also facing the same problem. i have xperia x compact with anroid 7.1.1.
model - F5321
BUILD - 34.3.A.0.252
customization-1305-2001_R2D.
It does not support VoLTE.. Volte provision is turned off, it slides to on but doesnt stay.
All phone manufacturer are giving software update for VoLTE , do not understand why Sony is not paying any attention. it would be a simple fix at their end. for us its a huge problem. In India its open carrier, they do not provide any firmware. reliance jio doesnt work without voLTE.. I was a huge fan of Sony , unfortunately have to give up, worthless support and forum, all you do is lock down the thread without providing any solution.
we are just wasting hard earned money for those who do not care about its customer.
I'm having the exact problem and my carrier has told me that it's my cell phone issue but i know it's not because nothing ever such happened which could break my phone and cause this issue.
Same here. Same SIM inside my old iPhone SE has VoLTE enabled. Not in the Sony. My carrier says the same: if the device is VoLTE enabled, it should be automatically on from their side.
I am using Xperia X Compact...US purchased but flashed UK firmware 7.1.1 for fingerprint reader. I am unable to use VOLTE at the moment.
Can you please help me on this? Which firmware are you using - UK OR US? How is this device holding signals with JIO sim as mine is pretty bad. Have you tried with Airtel too?
I can't enable VOLTE flag as you have advised.
Many Thanks in advance.
