Salve,
non mi funziona la connessione NFC: è successo a qualcuno? Come avete risolto?
Grazie in anticipo per l'aiuto.
Hello,
the NFC connection doesn't work: has it happened to someone? How did you solve it?
Thanks in advance for the help.
gt
Check, test.
Open the support app on your phone.
Tap on Xperia Tests
Find NFC
Test
