Память на устройстве полностью заполнена. Я удалила все фото на устройстве и карте памяти, перенесла их на Google foto. Но устройство пишет что нечего не изменилось и на телефоне 40 гб фото, хотя если зайти в хранилище, то галерея пуста. Помогите пожалуйста
The memory on the device is full. I deleted all the photos on the device and the memory card, transferred them to Google foto. But the device says that nothing has changed on the phone and 40 GB photos, although if you go to the storage, the gallery is empty. help me please
-GT
Probably something with syncing.
Get access from your computer to photos.google.com, log in and see what's there.
Connect your device with a computer and USB.
Find directory DCIM on your device.
Copy all content to your computer. (a photo folder you create)
Check and doublecheck if it landed on your device.
Then delete all content from subdirectory DCIM.
Just check, be curious, you'll find out.
