examples:
seems ok in safe mode. how can I check which app is making it wrong?
That's the tricky part. Sometimes putting it in to safe mode then restarting the phone can resolve the issue so please test it again after you have restarted, but if it is still happening you will need to start uninstalling apps and testing after each uninstall.
Focusing on apps that interract with the lock screen or the clock app first and working your way from there is a valid method. Or, if this has only happened recently, start with the newest apps and work backwards.
Before you uninstall anything though, make sure ALL your apps are updated.
thank you, issue is solved. not really sure which app caused it
