34.2.A.0.292 thanks SONY ❤
https://drive.google.com/file/d/0Byy3PUewHDFCSEFiYzNvTzlPdlE/view?usp=drivesdk
Hi @SOUNI1, sorry to hear that you were unable to update your device.
You can try clearing data for the Software Update app through Settings > Apps > [menu] > Show system > Software Update > Storage > Clear data. Reboot your device after this and it will search for new updates again and notify you when you can try to update again. If you have access to a PC you can also try to update using Xperia Companion. I hope this helps.
Hi @Alessio_84,
Update availability will vary depending on country and/or operator. I'm afraid I can't say when the update will reach your device but you will receive a notification as soon as it is available.
This update is region dependent?
Where you come from @SOUNI1?
Hi @Alessio_84,
@Christofer
Updates sometimes are only for some countryes and not wordwide. I only would have to know if this update is also for Europe (Italy) or is only for the asiatic markets.
I don't trust that you, Sony's employee, don't know for which country are updates released from Sony...
@Alessio_84 I'm afraid I don't have any information of that kind. I'm sorry if you don't believe me, I'd gladly let you know if I did know more.
@Christofer, no worry, I trust you and sorry if I doubt to you. I wait the eventual notification of system update on my X Compact.
Thank you so much and let know us about if you, eventually, have some informations. :smileysmileythumbsup:
My best regards!
@Alessio_84 Thanks for understanding!
If I get any new information about this I will make sure to let you all know.
Hi everyone,
after the update notify, I tried many times to install but it fails after the restart.
Actually it simply restarts, there's no usual android update interface.
Tried the solution given here (http://talk.sonymobile.com/t5/Xperia-X-Compact/New-System-Update-34-2-A-0-292-Available-for-X-compac...but still no working.
thanks for any support you could give.
