I have a problem with my xperia x lockscreen with fingerprint when unlocking the phone. After press button and scanning the fingerprint, the phone is not unlock in imediately. I have to input the back up pin again to unlock the phone. In addtion, I also see the icon on the bottom of the display if icon is a lock I have to enter a pin but if it is a finger print icon I can unlock the phone in imediately. Can anyone help me?
No, I am using stock home launcher. Thank you for giving me a solution. I can find the solution to solve the problem by disable "tap tap to sleep" feature of xperia home laucher.
You can try to add xperia home as administrator, maybe it works and you can unlock using fingerprint only.
