There is heating issue in Xperia x dual. It gets turn off the camera.
Another thing is we cannot record videos for longer duration, the camera gets shut down by frheating.
Please try to resolve it by giving updates. Otherwise it is useless to have. 🎥 is an important thing in smartphones. You can't deal with it as
I am also x user and sometimes the problem occurs to me as well. But if you record shorter interval of time (like 2-3 mins in fhd) then this problem will not occur. Try to record shorter videos.
I also hope that Sony will try to fix the heating issue while recording fhd videos for longer period.
I too have the same problem someone please help
My phone too have heatung problem please update sony so we can record longer fhd 60fps videos
the phone will heat up due to many things, if you are running multiple apps, if you have poor signal, if you have other radios open, etc.
