Every time I plug in my headphones, Google Voice will activate and try to listen. I will then close it down and carry on trying to listen to music, but if I nudge the cord at all Google Assistant will activate again. It's very annoying, espescially since I use my phone in transit and can't keep it dead still the whole time.
Does anyone have a way to stop this from happening? Or possibly even completely deactivate (or delete) Google Assistant?
Thanks
has this started up for anyone? i disabled Google assistant months ago but today she started interrupting again
This was driving me nuts too. My issue was that it was only partly set up. I remember taking the update that enabled it in my WH1000XM2 headphones but never completed setup on my phone (Oneplus 6T).
My solution was;
Look at the scematic papers of an headphone(internet) and see how the jack/plug is build ... So 3 sections bottem-mic(black) mid-left ear(green) upper-right ear(red)
I think i found the way to fix it without disabling the app, go to settings, apps, search Google, go to permissions, and disable microphone
