x
Can battery care be installed?
sniff
Visitor
is there a way to install battery care, found on xperia xz, on xperia x?
5 REPLIES 5
profile.country.PH.title
MarlonUk1
Expert
unfortunately no... you still have Qnovo https://qnovo.com/86-sony-xperia-incorporates-qnovo-technology/
sniff
Visitor
ok. thanks. still, battery care would hale been very userul. I have a 5 year laptop with a feature like battery care and I can tell you it's battery performance is comparable with a new laptop.
ksuuk
Visitor
You can install BattetyCare app (SmartCharger.apk), which is included in Compact X - https://forum.xda-developers.com/crossdevice-dev/sony-themes-apps/apps-apps-xperia-xz-t3454223
And then battery care menu is visible inside setttings > battery.
sniff
Visitor
thanks, I was looking after a way to install it from store or sony portal, or something like this. But I think there is no such think.
Shumayal
Visitor
It makes me curious if Battery Care is really so useful and safe, then why doesn't it come installed in by default?
Installing it as a separate .apk means you have to go through disabling security and so on. Can anyone from Sony confirm that this is totally safe?
Also apparently some Xperia X do come with Battery Care but others like in my region do not get it by default. Why is this? Is there any technical reason behind this?
