- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Can battery care be installed?
is there a way to install battery care, found on xperia xz, on xperia x?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
unfortunately no... you still have Qnovo https://qnovo.com/86-sony-xperia-incorporates-qnovo-technology/
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You can install BattetyCare app (SmartCharger.apk), which is included in Compact X - https://forum.xda-developers.com/crossdevice-dev/sony-themes-apps/apps-apps-xperia-xz-t3454223
And then battery care menu is visible inside setttings > battery.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It makes me curious if Battery Care is really so useful and safe, then why doesn't it come installed in by default?
Installing it as a separate .apk means you have to go through disabling security and so on. Can anyone from Sony confirm that this is totally safe?
Also apparently some Xperia X do come with Battery Care but others like in my region do not get it by default. Why is this? Is there any technical reason behind this?
