Just noticed, that X -s camera LED is darker and more yellow, than other my phones (Xperia V, Xperia Z1).
Do You have similar problem?
checking with another model might not be the best comparison for this,
I suggest that you visit a Sony Showroom near you and test with another XPeria X device, Local support
also the color of the light (yellowish) is corrected in the post processing of the image after taken,. but if you notice yellow hues on everything you capture with LED on.. try to contact your local support. (link above)
haha... same to me... is it usual or not usual ?
is it need to repaired ?
