Are there any free ways to extract the call history from a Xperia XZ3?
All I can seem to find are applications which are paid or apps on the phone which don't do as they say!!
Is this stored in a file on the device which I can download and read, perhaps? I need the phone number and duration of the calls.
Thanks
I believe there's a lot of apps that does that for you! However, not all of them actually works. But I would recommend contacting your provider first, maybe they have a way through the SIM card itself.
