x
Battery performance
SOLVED
Judysung
Visitor
Battery performance
Got my x performance two days ago and have been using it in stamina mode. Battery level dropped 15% in 4 hours without browsing the Web, only used for instant messaging... Is this normal? I expected longer battery life with this new phone
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.PH.title
MarlonUk1
Expert
first few days of using the device is not the best time to measure battery life, there lots of background processing happening ( indexing and calibrating and stuff)
try to search "battery drain" on the search bar above to view possible solutions
31 REPLIES 31
MarlonUk1
Expert
MelvinZ
Visitor
That's weird I use my xperia x performance heavily without stamina mode and get 6 hours of screen on time.
Judysung
Visitor
Hi both, there was something wrong with my phone as the applications crashed frequently and the phone would restart by itself. I took it to Sony and got a new phone. I've been using the new phone for almost a week and I'm happy with the battery performance!! Thanks!!
profile.country.DE.title
SirRobin
Contributor
Are this 6 hours of DOT with maximum display brighness? I think this is one of the most power consuming things...
I´m thinking about a switch from z3 to x performance but battery performance is a thing i´m not sure about...
Gruß Sir Robin
--> KD-55XE9305 --
MelvinZ
Visitor
I always get 6 or 5 and a half hours of screen on time with nearly max brightness.
tomo100brt
Visitor
Can someone tell me what is com.qualcomm.qti.tetherservice? My battery is drainig and I got 40% of usage by Android System.
Roberto17
Visitor
I got 5 hours and half screen on time with stamina mode ,Bluetooth on and half brightness .
tomo100brt
Visitor
Battery life
Is this OK for battery life? From unplug I did not use my phone, only mailing. I am concerned about Android System getting so high. And in Android System, com.qualcomm.qti.tetherservice is in proces. Is this alright?
survivant
Visitor
just got my phonme yesterday and the phone is draning too much the battery compare my to Sony Z1.
I restore the same applications with the same settings, and I unplugged to phone, move around without playing with it.  After 2h the battery at 89% for the X, and 96% for the Z1.
