Hi Sony Devs,
Recent updates with Xperia™ X Dual seems loosing enough stability. I have noticed that my phone gets easily drained after the latest updates. Mine is running the w/ the latest Xperia X update and is only getting closely 4hrs of display time, before it gets to 5hrs.
Dramatically, speaker seems loosing its volume. Please check on this Sony devs, this is a very great phone.
Thanks,
Ahrkitek™
Sometimes software has to settle after an update.
Sometimes deleting apps can help.
Sometimes reading about battery care in the manual can help you gain longer battery life.
Not trying out all tips and just performing a factory reset is often the best way to improve overall performance. (don't restore all apps, just the ones you can't live without)
Hi Strampke,
Is it really best to do a factory reset? Or should I just wait for the next update?
Since I do not also want to reset and restore again my phone.
Thanks,
Ahrkitek
Then wait.
I think the september security patch will land very soon.
Take care that the battery is loaded at >50% , prefarably 80%
And if the update solves your problem, would you be so kind to mark a regular software update as a solution?
Isn't it the September patch what I have just updated last week. Or maybe I should have to wait for the October patch.
Anyhow, I just need an update to bring back the longer battery life and top notch performance.
Appreciate your replies buddy. Will mark it soon once they nailed it on the next update and probably will not be updating anymore.
Cheers,
Ahrkitek
Still: Factory reset combined with just installing the most necessary apps is best to regain performance
Indeed it is.
Except for the messages cannot be saved.
