@Shumayal Indeed the screen recorder is gone:
/t5/Xperia-XZ/how-to-screen-recording/m-p/1175868#M1747
Also, the mobile data switch works as intended on android N:
/t5/Xperia-X-Performance/Android-7-usability/m-p/1187881#U1187881
As for the battery care, see this:
/t5/Xperia-X/Can-battery-care-be-installed/m-p/1191245#M1821
Sorry, I couldn't find the same issues raised earlier and created a new thread.
Appreciate your reply! I hope Sony hears us and makes these small changes.
No worries, some of the issues have been escalated but we can't promise anything.
For some questions, there are workarounds, like for the screen recording thingie.
