Hi, I have an Xperia x with android 8 and I wanted to ask if anyone knows if I will be able to update it to android 9.
thank you
All the info on Android 9 updates is here >>>
/t5/Software-Updates/Android-Pie-9-When-are-we-getting-it-Which-Xperias-will-be/td-p/1306563
