i update my sony xperia x in nougat then there are few problems in my application and it cannot update the incoming os.
Hi @jerort, sorry to hear about this.
Do I understand you correctly that you aren't able to use some application in your phone after have updated the software? If that is correct, have you made sure that these applications that you can't use are updated to the latest version? You can check that in the Google Play store!
Let me know how it goes!
