The accelerometer of my x performance stops after some days so auto-rotate and other stuff does not work anymore until I reboot...
I bought this phone in Hong Kong and I am traveling a lot ... the update release depends from where am I ? ...or just from when it will be released in Hong Kong?
(Still having the issue with build .282, very annoyed and thinking to buy a new telephone).
Excellent! \Ü/
An update is rolling out! Hopefully my carrier won't hold this of for too long.
Kudos to the community for the suggestions and temporary workaround.
Thanks to Sony for looking after and releasing a fix.
Regards,
Still nothing in the Netherlands,
getting real tired.... Mailed sony Netherlands, they aren't even aware of the issue and blame it on the hardware...
SONY when does the update come.
ps already tried all the steps with location history, doesn't work for me.
I doubt we get another reply from sony, they of course consider this solved...
Im gonna wait till december, if it isn't solved by then im gonna return it and buy another brand.
I have the same problem and it needs to be fixed.
Or else i have to claim my money back. This is a major problem for me.
