The accelerometer of my x performance stops after some days so auto-rotate and other stuff does not work anymore until I reboot...
The screen have stoped rotating. Example when looking at pictures, in Chrome etc and rotating the mobile to get it turned 90 degrees and filling the whole screen.
"Rotate automatic" is activated but still no rotation. After restart it worked once, but the problem reoccured and restart is no longer working.
Any idé what is creating this?
The location history only records where you have been, as opposed to location services which is used by apps like Pokemon Go & Chrome & Maps to help you navigate places some more info can be found in an article by Alex Dobie at Android Central
