The accelerometer of my x performance stops after some days so auto-rotate and other stuff does not work anymore until I reboot...
Disabling Google App helped for 3 days. After I've used Maps bug had returned.( Waiting for fix, very disappointed.
Disable location history as mentioned is temporary fix the problem which it work fine from yesterday until now
Hello !
i just got a NEW sony xperia Xpreformance and the auto screen stops working all the time. i tryed the dignostic but its failing . same with the shaking sencor .
I have had this phone for 2-3 weeks. and i notis it when i was watching youtube that i couldnt get fullscreen with just rotating the phone to the side.
Its working after i restart the phone . but i dont want to restart it eveytime.
do you have any tips what i can do ?
what can be the problem?
I did try it later yesterday. and so far so good.
I let you know if it stops
