The accelerometer of my x performance stops after some days so auto-rotate and other stuff does not work anymore until I reboot...
I'd like to say thanks to everyone who send us logs of this and again apologize for any inconvenience this is causing.
I've just received information that a new software update will be available shortly with a solution for this.
Until the new software update is available, if the accelerometer, gyroscope, magnetometer, ambient light, proximity sensor, barometer or screen rotation stops responding, please try to restart the phone as a workaround.
Hi There,
Just got a called from Sony Thailand. They found the cause of this problem when removed Google update the problem was gone.
Waiting call to confirm to bring my phone back.
@Rickard wrote:I'd like to say thanks to everyone who send us logs of this and again apologize for any inconvenience this is causing.
Thank you this is the news I was hoping for... Was almost about to take my phone back for a refund.
Question is this software update will sony release it directly or will it have to go through my carrier Telstra (lengthy) testing process?
Dear Rickard,
Could you please kindly share some technical details regarding the problem?
Thank you.
