x
Accelerometer stops working
SOLVED
Mikvandorp
Visitor
The accelerometer of my x performance stops after some days so auto-rotate and other stuff does not work anymore until I reboot...
Tags (1)
410 REPLIES 410
profile.country.DE.title
webwude
Member
I installed the maintenance update days ago and it is still working. At least it is definitely not a fix for all to uninstall it.
Alejandro88
Visitor
I'm experiencing the problem only when I start the camera app, after every reboot autorotate works perfect until I try to take a picture.
joima
Visitor
OK, so far, non of following has been working:
- Uninstall maintenance update
- uninstall update of what's new (it gets force-updated after a while)
- disable google app
PimN
Visitor
That's where it started for me..
Vikont
Visitor
All,
Need your assistance.
Who have Google search widget on initial screen?
I deleted it and have more than 24h stable work.
Thanks
Olsun
Visitor
i havent used the phone for heavy usage other than surfing the web and calling the auto rotation didin't stop.
Guess the overheating is affecting this
abois
Visitor
I agree because the first time the auto rotation stopped working was after a 4h drive with Google maps and music on. The phone was hot.
Elohel
Visitor
Uninstalled updates for memory app, 15 hours now and rotate still working.. Here's hoping this is the fix
lee9505
Visitor
How to uninstall update for memory app ?
I guessed it cause by What's New, but it not the only one reason.
So, I uninstall the Google app, and reboot the phone, I have 8h stable.
Elohel
Visitor
I spoke too soon after about 16 hours after uninstalling memory app rotate stopped.. Sigh.. Will try uninstalling what's new now..
