The accelerometer of my x performance stops after some days so auto-rotate and other stuff does not work anymore until I reboot...
Same problem with my X performance (F8132) since a few days ago after update to latest firmware 282.
Both Accelerometer and Gyroscope stop working after some time when device restart (minutes or hours) and it is only solved after restarting the device again. It is really inconvenience, please urgently help to fix this, Sony.
I'm very sorry to hear that the update didn't help and we are still looking into this. I will update you as soon as i have more information.
Yep....factory reset nor PC Companion system repair does not fix this ongoing issue. This is on a F8131
Guys, as writtem above I have a similar problem affecting accelerometer and gyrosope.
I have tried many thinghs (removing apps, factory reset etc..) ...no success.
Very disappointed.
Hi Rickard, I have the same issue. Is there any way to fix this issue, I don't know by wiping the rotation data or anything?
Is there a next software update planned to fix this?
Please let us know if you have any news, thank you.
Whooops....I needed to reboot mine as the proximity stopped working as well. All Sensors are operational after boot, but lasted only a few hours.
Good thing I am always on headphones so I don't make good use of the proximity sensor except the Brightness (w/c can be manually adjusted)
